RCU Forums - View Single Post - DD - what engine
Old 08-24-2006 | 06:05 PM
Mike Connor's Avatar
Mike Connor
Default RE: DD - what engine
ORIGINAL: izzy
i am considering either the Jett F1 or F3D engine , or the Jett 50 FIRE
the reason i am considering the JEtt F! , is because it should have more RPM on an 8 " prop , and will probably pull the dust faster
thanks
Izzy
I vote Jett FIRE 50. After owning two DD's and following their threads for years, I don't think the small diameter props will give you much speed advantage. The Dust is not clean enough to avoid the thrust = drag speed barrier IMO.
Other things to consider:
A throttle is nice. I can not imagine not being able to throttle back to prepare for launch. Not much to hold onto.
Serious mods are needed to mount a rear intake engine. It can be done though.
