RCU Forums - View Single Post - Stryker Brushless help! Motor suggestions.
Old 08-24-2006 | 07:33 PM
bleary's Avatar
bleary
Default RE: Stryker Brushless help! Motor suggestions.
Yoster that motor will work ok,as will many others.You need to start with your batteries,and work your way from there.Using lipos as an example,if you have a 20C 2100mh 3cell,you theoretically can draw 42 amps from them....not a good idea for battery life,just say you have a battery capable of suppyling mid 20s up to about 30 amps,which is what I work on.You are going direct drive,and be using a 6 or 7 inch prop.A Mega 16/15/4 has a kv of 2200 and will draw about 23 amps or so on 3S with a 6x4,and is a nice setup.Using a 6x5 improves speed,at the expense of more amps.I use this motor,and also Align motors of 2500kv,they spin faster =more amps.
What can your batteries supply? thats where you need to start.
Cheers,
Bleary.
