RCU Forums - View Single Post - How much washout in a trainer?
Old 08-24-2006 | 07:52 PM
dbacque
Default RE: How much washout in a trainer?
I think the best answer is to build it according to the plans. A good trainer will have dihedral, washout, incidence, etc. all worked out and the instructions should walk you through everything to do to build a good, solid flying airplane.
If the instructions don't tell you to add washout, that usually means the plane doesn't need it.
Dave
