RCU Forums - View Single Post - os 52 fs surging please help
Old 07-23-2002 | 09:06 AM
FHHuber
Banned
Default os 52 fs surging please help
How thick is the white smoke comming out the exhaust? (at high throttle)
If its thick and very easilly seen in flight... you're rich. If you can't see it at all against a CLEAR blue sky, you're lean.
I'm betting you're on the rich end... this causes the engine to spee up as you enter a loop, peaking just before you one on the vertical downline, and then act like its going to die just as you level out. (full throttle the whole loop) The exhaust trail tapers to about what it should look like all the time about the top of the loop.
It is also possible that the engien simply doesn't like that 11X7... On my .91 I noted a full turn difference in needle setting changing from a 14-8 MA wood to a 14-6 APC grey nylon Pattern prop. The engine surged(as in the rich in loops description above) with the 14-8, and is rock steady with the APC. Leaning more with the wood prop made the engine overheat... so it was too much prop.
