RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 08-24-2006 | 08:51 PM
  #5297
Barry Cazier
My Feedback: (17)
Default RE: U-Can-Do 3d 46?
Kostas1...
The OS 4 stroke will be a good choice. I think the Saitos make more power and are a bit lighter. With a Saito 82 balance is no problem. With the heavier engines you will probably have to move the battery in the back half of the fuse. Not hard, but a bit of work.
You'll be much more satisfied with a 4 stroke engine in this plane. Generally the 4 strokes are even a bit lighter, due mostly to the muffler.
The 4 strokes are not hard to use at all. You'll be pleasantly surprised how good they run. Especially inverted. Sometimes the 2 strokes have a problem inverted. The UCD requires the engine to be inverted.
Barry
