Originally posted by 2lo
Has anybody used the Monokote trim solvent? Does it work very well?
I assume you mean to put Monokote over Monokote (not to remove the trim with the bubbles). Yes, Monokote trim solvent works great. Everybody should read AnnMarie Cross' article on the subject at
http://www.top-flite.com/reviews/trimgraphics.html
I use trim solvent a lot for smaller pieces of trim (say up to 2" by 2"). Anything larger, I use the Windex method.
Make sure you have a big fan so you have fresh air to breathe while you're working with the stuff!
