RE: Hitec Fusion 9 receiver...
Sometimes when your transmitter antenna is down it can cause a slight mistune of the
transmitter and may be causeing the symptom you decribe. have you swaped receivers
to see if the fusion is definitely the only receiver with the symptom?
Also is one surface glitchin are all of them? i have my eye on the fusion 9 and would
like to see how this turns out. by the way who has the fusion in stock?
