RCU Forums - View Single Post - Does Anyone have software to calculate Polars?
Old 08-25-2006 | 06:50 AM
mesae's Avatar
mesae
Default RE: Does Anyone have software to calculate Polars?
Profili:
http://www.profili2.com/eng/default.htm
Profili has a very nice friendly interface with XFoil that makes it useable for the "rest of us". I believe you need to pay a small registration fee to unlock the full XFoil interface but if you are building a 40% model, an extra €10.00 EUR is well worth the investment, and only a tiny percentage of your total cost.
If you really need someone to run the numbers for you, you might want to post root and tip chords and specific airfoils and/or thicknesses. You might also want to say what you are building a model of. There's much more to an airplane's handling than just it's section characteristics. It's a bit time-consuming to run a bunch of polar sets and I wouldn't have time personally to do that for at least a couple of weeks but maybe someone else can help sooner.
Also, the reasons for not using the scale airfoil are not obvious based on the information supplied. Some airfoils scale down just fine, depending on many factors. Airfoils that you generally do not want to scale down exactly are high-speed airfoils that have drag buckets tailored to the full-scale airplane's cruise speed. The drag bucket will not translate to model size and speed and will almost certainly not be optimum for the model and will likely provide poor low-speed handling.
