RCU Forums - View Single Post - Problem with Saito 82
Old 08-25-2006 | 09:29 AM
Born2Fly
My Feedback: (21)
Default Problem with Saito 82
Hi,
I need help with my Saito 82. Engine is new may be 1 gallon thru. It is installed on Seagull Harrier 46, without cowl. It swings 13x6 Master airscrew prop and I am using 20/20 YS blend fuel. It was working nice since I bought it, start with the first flip and never died in the air. 2 days ago I was flying and it quit on me, I landed safely. I tried to start it and it was perfect idle, but when I am adding a throttle it quits right after ΒΌ of the throttle. I re-adjusted needles, low to 2 turns out and the high to 2 and the half. I let the engine cool off a little, and it was running good again. I tool the plane in the air and after 5 min 40 seconds of flying it quit again during the loop. Engine seems to be a little hotter than is should, but it is not lean. I am always running my engines a little rich. I also notice that if I put the pressure on the low-needle while engine is running, it drops rpms and quit.
What can be a problem? Thank you in advance.
