RCU Forums - View Single Post - Problem with Saito 82
Old 08-25-2006 | 03:02 PM
Tjen il-vec
Default RE: Problem with Saito 82
Your welcome
I hope it is traced back to your fuel setup. That rules out any problems with the engine and it's an easy fix. Try the viltclunk, the nipple is a bit larger so the chance that you lose it is very small. If you decide to use this clunk, get rid of the filter in your fuel line. 4 strokes can be very critical in performance with any debris, air or obstruction in the fuel (flow).
Good luck!
Great engine by the way, excellent power to weight ratio!
Cheers
