RE: Kyosho Twin Storm 800 Owners!
The Kyosho 4mm U-Joint at both ends is much shorter and will give you much less work to apply.
See my previous photo and discussion.
Metal prop? No where. I have been waiting for four months for my Korean boat. TS? Use plastic is good enough.
If you wish to use 8 cells X 2, you need to change a few things. Look out too fast as it will flip your boat too, even at straight line. Hard to make sharp turns. Water etc., overheating, melting (including Dean plugs) etc.
Read our old old discussions.
