RE: HENG LONG OWNERS ONLY THREAD!
hl suspensions are too stiff, it depends if you wanna add more accessories.
suspensions can be adjusted simply by drilling another spring attaching hole near the original one or by adding weights.
the motors are strong, the climbing angle or degree ,depends on the traction, not the motors.
this tank is little more fragile then your tamiya, but it is fast and easy to fix(fun) when sad things happens and parts are cheap.
so
if you can use a screwdriver and a soldering iron for wires,go for it,
you will enjoy this 99$ tank.
take the s&s version with metal gears ,
no plastics gears>safety clutch does`nt last long in rough conditions .
