RCU Forums - View Single Post - How to do an ignition test
Old 08-25-2006 | 07:59 PM
texomalaser's Avatar
texomalaser
Default RE: How to do an ignition test
I stick my finger in plug recepticle and if it hurts its working...Naaaa!! Just kidding. I had to though..You left that one wide open...
Plug the fully charged battery directly to the ignition.(bypassing the switch) Make sure the plug is good and ground it good to the case of motor and turn her over. If no spark occurs its more than likely bad. Hope this helps...
