RE: Norvel Engine FAQ
PSvan.. Are you saying, that the needle just rotates, when you turn it Clockwise, and, never stops/bottoms out..Have you taken the Glow plug out of the cylinder and checked to see if it Glows.Does the engine at least pop? When you prime it, does it, at least burn off the prime, and, run for a second..These are not overly complicted engines..Please explain exactly your situation as to what you Are doing ,and, What the engine is doing too..Opps,Sorry, I see you have had it running..the idle Rpm on these engines is 3500 RPM you can`t expect it to run much slower than that..If the engine is not fully broken in yet ,it will be "Tight",and not want to idle ..Do you have an Instruction Sheet with your engine??Let me know ,if you don`t ,and ,I can scan mine for you?
