I have no idea why it won't work. link is on, mix is on.
The only mis that is not working is the throttle to rudder.
Only one of the two rudder servo's will operate in this mix.
The rudder servo's both works fine all other times.
I don't have throttle to aileron, I have rudder to aileron
for roll coupling and rudder to elevator for pitch coupling.
I use the point mix's with the graph for this.
I am only looking for throttle to rudder so when the plane is
in a down line on low throttle I can get 1 or 2 degree right
rudder.
ORIGINAL: Bax
I don't know what the difficulty may be. I set up my 9C transmitter just as you mentioned, and all the mixes worked properly.
I used prog. mixes #1, 2, 3, 6, & 7, just as you did. They all work. What is not working when you turn on the mixes? Are any still on "INH"? Did you forget to turn link and trim on where appropriate? For the throttle->aileron and throttle->elevator mixes, did you set percentages on the graph?
