C.G. for a St. Croiz model 1/5 scale Long-Ez
Here's the control surface throws, in case you need them.
Elevator: UP 3/8" (for dive)
Down 5/8" (for climb)
Remember, the elevator moves opposite of a conventional tail aircraft. When the ele. moves down, the nose pitches up.
Ailerons: UP 5/16" DOWN 1/4"
Rudder: 3/4" out only
Nose gear: 12 to 15 degrees either side of center as usual.
Hope this helps.
