RCU Forums - View Single Post - RAM 750 CP to Thrust Values
Old 02-03-2002 | 05:33 PM
Woketman
Default RAM 750 CP to Thrust Values
Mach 1, are you certain that you are asking for the values for a 750F? The reason I ask is that the ECU that came with the 750F was not adjustable for max CP by the user and so they did not give you a CP vs, thrust table in the manual. If you have a 750P, the ECU was adjustable (when you get to the correct point in the set up menu, every time you hit the start button, the red one, it lowers the max CP by 100 mb) and I have the values of CP vs. thrust for that.
