CP Values
Yep, it's an F model...I just changed the 'old' ecu for one of Andy's
that allows you to set max cp and glow values. The RAM ECU would take the engine to 1325 max. Andy lists in his manual that
his ECU was preset for max at 1314 mb, however when I was
going through the set up, max was set at 1413 mb. The next
step down is the 1314.
There is a CP/Thrust chart in the manual for the 1000.
Is it fair to assume that the 750 and the 1000 are
producing the same thrust up to the 750 max cp limit?
