RAM 750 CP to Thrust Values
P.S. Were you at Superman 2001? If you were, you may have seen my Hot Spot flying. I had a 750F running at 1400 and it had tons of thrust for that Hot Spot. I only used it vertically as I was having that aeroelastic issue with the wings where they were flexing at high speeds. So I basically just did touch & goes, slow flight and vertical climbs to be safe until I could glass the wings.
