ORIGINAL: bigbadbowtie
ORIGINAL: Kemo
that and they have an ignition system that stops the second they shut down the vehicle.
You are correct....but they don't cut the igntion until after the engine has quit from the lack of fuel. Trust me I have been in drag racing for many year,
KX..... You have seen the inside of our little 2 strokes after being run... COATED with oil. I HIGHLY doubt 2 seconds of a lean condition at idle will ever hurt anything.
How much oil is in your fuel? Most of what I use is always burned off. Because if there was that much oil in there, there would be no need for after run oil
