RE: Glider cradle causes tow plane instability
oops forgot to explain how it works, in case it is not obvious. When the servo is actuated it pulls the rod, releasing the rubber band that holds the doors closed. I do need to make a provision for retaining the rubber band, as it is now I lose one every time I drop something. It installs easily, a pin retains it in back and 2 screws in front. then just hook up the plug that I use for my actuation switch channel. I can use this mounting for all my hang on toys.
Denny
