RCU Forums - View Single Post - Tx/Rx battery question
Old 08-26-2006 | 07:19 PM
sparky577
Default Tx/Rx battery question
Last weekend I bought two GWS 1600 mah NiMH packs. I refigured one to use in my transmitter, and split the other into two receiver packs. I used a soldering iron and quality solder, along with JR factory battery pigtails. I have cycled them twice with a Hobbico Accu-Cycle charger. My question is, The transmitter pack discharged 1108 mah in 135 minutes. The receiver pack only discharged 510 mah in 62 minutes. Shouldn't the receiver pack be about the same as the transmitter? or did I get a bad pack? The charger has a set discharge rate of 250 or 500 mah. I set it on 500 mah. It also has a 125 mah charge rate, and a set 15 hour charge time.
