RCU Forums - View Single Post - HL Pershing inside question
Old 08-26-2006 | 09:52 PM
Harquebus's Avatar
Harquebus
Default RE: HL Pershing inside question
That's cool! An all-weather Pershing. Did you block off the rear gratings so the rain would not fall through into the electronics and/or into the hull or does the CorrosionX treatment just prevent moisture from having any ill effects?
Seems you might need a bilge pump to pump out the water if you didn't seal the rear hull gratings/vents... [sm=drowning.gif]
-Harq
ORIGINAL: swathdiver
I haven't had a chance to take and post pictures (guests staying over) but I've used evergreen styrene .020" placed along both sides and the rear of my Tiger tanks. This is secured in place with clear rtv (silicone) and also in the rear. On one tank, the electronics have been coated with CorrosionX with no problems at all. I even ran one completely stock Pershing the other day in a pretty heavy drizzle for over 30 minutes without a single problem! ...
