RE: Masking Tape Blues
Try some Isopropyl alchohol (rubbing alcohol) on a q-tip. You may have to repeat the process to get them clean, or go to your local automotive parts store, and get a can of adhesive remover. This is the stuff thay you use to get the glue off a car when you have removed the tape graphics/pinstripes. Use a little, because it goes a long way. The little woman's fingernail polish remover may work as well, but be careful, this stuff may ruin the paint job if you are sloppy.
Bill, AMA 4720
