RCU Forums - View Single Post - JR10X Flap programming problem
Old 08-27-2006 | 08:42 AM
rcjet lynch's Avatar
rcjet lynch
Default RE: JR10X Flap programming problem
I usually take the servo horn back off with the switch in the up position and physically move the horn to the flaps are in the full up position with all of my sub trims zeroed and then start my adjustments. This is not uncommon to find that when you use the slider you have to reajust your linkage when you go to the switch.
