RCU Forums - View Single Post - tach engine problem
Old 08-27-2006 | 09:07 AM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: tach engine problem
Well I fought this unstable/is it correct? tach problem for awhile and got really tired of it with stuff that was sensitive to where the sun was or shadows interfering with readings.
Then Fromeco started building TNC tachs again and that solved my problem... [8D]
http://www.fromeco.org/shop/atnc%20tach.htm
You can buy them direct, or there are several other vendors that stock them. They are a little more money but pretty much eliminate the problems you've noted. Those tachs were very well thought of around here from what I was able to find, but had gone out of production until Fromeco got the rights to build them again. Try it, you'll like it!
