RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-27-2006 | 09:21 AM
  #2665
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
ORIGINAL: jonny didmo
I guess this is last unsuccessful pic I will post, no doubt it's become tedious... Got an ok extended power glide from this. Realized I had put the motors on w/ left & right swapped - so I tried it upside down. Went much further, but still, little turn capability, and no altitude gain. About 35' from a 5' launch height. Not a good flying day anyhow, too wet. Good day to begin another plane. 2 ea. 7 1/2" dia. wings probably just too much lift area and drag, or perhaps should have staggered wings.
If the wings are straight with the stab you will get no lift. Angle the TE of the wings
down a bit or bend the tail boom up so the TE of the stab is up. You need to get some
air under those wings. Put the plane in front of a fan. When you lift the nose you'll
see where it starts to take off. Start from that angle.
