RCU Forums - View Single Post - The new Lanier Edge 87"
Old 08-27-2006 | 09:22 AM
  #291
shesha
Default RE: The new Lanier Edge 87"
OKay finally got round to finalising the plane, here are the pics, I decided to go with the a smoke system, and as you can see I have added an equivalent smoke tank. Will have some more pics up later today with more shots of the final touches .
The C.G did not balance out at all as per the manual, as per bonedoc's c.g neither, I will have to wait and see if it balances out once a spinner is in place.
If all else fails I might swap out the smoke pump with a sullivan smoke pump that may address the problem, lst resort will be dead weights.
I dumped everything at the front of the plane there is nothing left to add, also I decided to opt with a single pull pull single servo setup for the rudder as per bonedocs building tips, looks like a winner.
Maiden flight schedule in the coming days will see what the result is.
ID:	513903   Click image for larger version
ID:	513904   Click image for larger version
ID:	513905   Click image for larger version
