RCU Forums - View Single Post - ECCPM Heli's ?
Thread: ECCPM Heli's ?
Old 01-08-2003 | 01:06 AM
Culverson's Avatar
Culverson
My Feedback: (14)
Default ECCPM Heli's ?
ECCPM mounts the servo pushrods to the swashplate similar to a equalateral triangle. Three servo's allows the swashplate to be tilted.
Your mixing is done electronically, so will need a radio to support the function like 120 degree is one of the most popular. Not all radios supports this, so look specifically when deciding on a radio that does offer support for this set-up.
You will need 3 servos (same model servos) that have the same torque-transit speed so the torque & speed will match each others movement timing. Some reccomend using digital servos, but I have used digitals-non digitals with good results.
