RCU Forums - View Single Post - Evolution 46
Thread: Evolution 46
Old 08-27-2006 | 07:53 PM
skiman762's Avatar
skiman762
Default RE: Evolution 46
ORIGINAL: blw
The Alpha is a .40. The TPS is a .455 and was marketed as a .40 by Horizon/Evolution for a while. The Alpha and .46NT share the same crankcase, bearings, carb, and cylinder. You can turn a .40 into a .45 by using the .46NT piston and liner. The crankshafts are slightly different. The crank pin on the .46 is slightly farther out. The .40 is better balanced but you could turn it into a complete .46NT by swapping crankshafts.
I remember my .46NT as taking a couple of tanks of fuel to smooth out and fly like it was broken in. I put it on a plane that previously had a TT Pro .46 and OS .46FX in it. The Evo had more power than those two on the first flight and it just got better. Of the two engines, my .455 is the better one.
Is the Alpha you refer to as a .40 an older evo engine or are you talking about the .45 evolution trainer power system used on the Aplha 40 RTF airplane?
