Swapping tracks on HL's
For any that care you can swap the tracks of each tank as long as you swap the sprockets as well. I took off 3 links from the Pershing track to get it to fit on the walker in the picture. I might be able to take one more off but it looks cool the way it is.
The sprocket teeth do match so if your willing to widen the walker sprocket or narrow the pershing sprocket to match the track profile. The Walker sprocket is about 4-5mm narrower then the Pershings.
So what does this mean? Well it means there is a lot of potential to mod these tanks into various styles of different tanks. Assuming your into that of course...
