ORIGINAL: dw_crash
I am a bit annoyed though at having to spend a couple of hundred bucks to fix the problem. But, Joe guarntees a perfectly running engine after it's done. Makes me think......
DW_Crash
Good result as its a 2nd hand engine. Joe has previously posted out new CCs to many customers who were lucky enough to get their JJ turbine running then found running actually destroyed the non inconel sticks in the CC. So if yours is >No 750 it is worth while getting the right CC put in. If you are direct Jetjoe customer that will be FOC since it has to be fit for purpose. Makes me think why a Turbine manufacturer would put inferior metals into his engines[:-][:-].
Paul
