Byron Fan, OS 91 DF, what pipe???
if you go with the byron or TGA pipe that is telescopic and adjustable, you may need to lengthen it to about 1" longer than the 12 1/2 ?? inches they call for. I was getting lean runs, blown plugs, loose head bolts and loss of power and couldnt figure it out, "it was my first DF" then a friend from atlanta told me to lengthen the pipe to 13 1/2 based on his experience. IT WORKED, from that day on with no more problems. Also get the JMP System 1 o-rings that are WHITE , they will last twice as many flights as the red. I always changed my plug after 3 flights and my o-ring after 6. Probably could have gotten away with more but they are cheap parts. russ
