RE: 18CX engine not starting
No its a hobbypro and i pulled the glow plug, the one that came with the engine was bad, so i put the one that came with my old one on and it works, so there is fuel flowing into the engine, and the glow plug does work. The engine is not flooded, i only primed it until i heard fuel enter the engine. The assembly that attatches to the end of the crankshaft, which has the clutch and crank are not on the engine. I could not get them off the old one. So all that is spinning is the end of the crankshaft, which has a threaded end.
