RCU Forums - View Single Post - 18CX engine not starting
Old 08-29-2006 | 10:45 AM
jguitarsandcars
Default RE: 18CX engine not starting
so, does it work now??? If not, and don't quote me on it, but if you don't have the clutch and flywheel on it, there might not be enough rotating mass to keep the crank spinning as you turn it...the rotation mass is what helps it turn against the pressure of the engine...
