Are you saying the ring is not the issue as much as a stuck ball bearing that may skid.
Correct. A stuck ring may cause some loss of compression for a while, but will cause no real damage. A ring should become unstuck in just a few minutes of running. In your case it sounds like the oil is not completly congealed, so both bearings and ring should be OK without a long soak. If it feels smooth it should be OK, this would mean any balls have disolved or become soft enough that they would not be a problem.
