RCU Forums - View Single Post - 18CX engine not starting
Old 08-29-2006 | 02:05 PM
Siscim23
Default RE: 18CX engine not starting
OK, ill put them onto the new engine as soon as i can get them off the old engine. There was a screw on the tip, that broke off so i couldnt unscrew that. I got the crank off the crankshaft, but the flywheel and clutch are still on the crankshaft. There is a nut on the end of the shaft that i cant loosen by turning it either way. How do i get the clutch and flywheel off of the crankshaft? I can supply pictures if that will help understand what I'm dealing with.
