RE: Beginner with BCPP
Is there a way to get the cp pro airborne quicker? mine goes to the left so quickly when I slowly give it throttle, that it is on the other side of the large meeting room that I have been learning to fly it in before it is airborne and then it tilts right. I know it is going to drift left somewhat and tilt right in the air, but I either throttle up faster and then give some right stick to get it airborne - halfway across the room, I give it to much right stick and it tips over to the right, or to much throttle and no right stick and it spins violently and then dumps. What is the best approach to get it as close to a vertical takeoff as possible? Im use to the vertical take off of the cx, I know its not the cx, bit I'm guessing there must be away to get it a lot closer to it then I am currently.
