RE: Technique for loose servo screws: help
C.A. does the trick, you can fill with bulsa before adding CA.... If not, and you donot
want to use a bigger screw, You can pull the servo and CA a small piece of light ply
and redrill... If you add the CA during the build, and not over tighten they will last
pretty long...
