RE: How to Detail the New PST Panther
Next we will fill any voids around the tubes with thick CA and Zip kicker FROM THE INSIDE again not getting any glue on the outside.
Use your Dremel with a cutting wheel or a Zona saw and trim off the excess tubing on the outside of the cone.
Fine sand the excess off with some 100 grit sandpaper on a block trying not to scratch the nose cone any more than you have to.
Cut four (4) pieces of 3/16 dia. thick wall tube for the gun barrels 1-.750" long, four (4) pieces of 9/32 dia thin wall tubing .125" long and four (4) pieces .375" long.
Use thin CA and glue the .125" piece .250 from one end of each 3/16" tube and glue the .375 piece flush with the other end on each piece.
Cut four pieces of 1/4" OD dia tubing .375 long and glue them over the 9/32" .375" end. This will be the spacer to center your guns in the 1/4" ID tube glued in the nose cone.
Kinda like this:
