K4.6 engine problems...need help.
hay guys.
I just tried to start my K4.6 engine.
first time i ever tried to start it, first i heated it with a hair dryer. than i primed it.
tried to start it and it wouldn't start....checked to see if any fuel going to the carb,
yep there was.
than I unscrew the plug and turn the engine over, and all the fuel came out. so I
guessed it was flooded.
than I heated it up again with the hair dryer and tried to start it again. but after about
the 5 pull it locked up again. So i unscrewed the glow plug and tried to pull the pull-start
but it wouldn't turn and no fuel was on the top of the piston...so I tool the cooling head of
and tried to turn it, but still no luck. Than i took the pull start of and the back plate of,
there was a bit of fuel in the crank but not much.
I than tried to turn it over with the fly wheel.....But it just wont turn over, and i don't
want to brake anything...
Do you guys know whats wrong???
