RCU Forums - View Single Post - K4.6 engine problems...need help.
Old 08-30-2006 | 07:54 AM
Nathan9492's Avatar
Nathan9492
Default RE: K4.6 engine problems...need help.
u have probably heated it up with the hair dryer so much that wen u have pulled the pull starter the piston has gone to the top of the stroke and then the engine has cooled down on the piston causing the piston to get stuk, try to put some ARO down ther and see if it will budge, IDK just a thought, hope it helps a bit, Nathan
