ORIGINAL: hmdlm
I think I am running too rich myself, but the problem is I go 300+ degrees with just a little wide open running. I have gone back to factory setting many times and tried to start back over. what do you run in general for a idle setting, I don't think there is a factory setting for it. I start 3 out on the high end, and flush with the low end. But the screw underneath the air filter I have never found a factory setting for it..........but I have tried it just about everywhere and anywhere
Did you look in the manual as I think there is a setting for idles in it as well as the rest of the needles? Starting to wonder if you have an air leak?
