RCU Forums - View Single Post - Higher Compression
Old 08-30-2006 | 11:36 AM
av8tor1977's Avatar
av8tor1977
Default RE: Higher Compression
Hi,
Yes, it will run, and probably pretty well as long as your carb can flow enough methanol. You may have to modify the carb passages to make them larger as the engine will need nearly twice as much methanol as it would gasoline. It will run either with conventional ignition or glow. It would run better with 3 to 5% nitro.
AV8TOR
