RCU Forums - View Single Post - Brushless
Thread: Brushless
Old 08-30-2006 | 01:22 PM
jdoug
Default RE: Brushless
I believe you can. I've heard of others using stick radios with aero controllers without problems. With the stick all the way back, it is the same as applying full brake (pushing forward) on a pistol grip radio which is why I had to rubber band the trigger forward. You shouldn't have a problem if you can take the centering of the throttle stick out.
