RCU Forums - View Single Post - Exactly how do you use after run oil?
Old 01-26-2003 | 03:14 AM
balsa brain
Default Exactly how do you use after run oil?
I run the fuel out of my engines after every flying session and fill them with Marvel Mystery Oil.Just turn your engine over enough when you are ready to fly again to get it out.Helps to remove the glow plug,just watch out if you're useing a starter to turn it over,as it will go everwhere.
Bill
