RE: Offical nitro tc3 thread
"the fix" as you are refering to is actually for the shock tower comming loose or actually breaking the diff case where the screws go into ( the ones that hold the shock towers to the diff case) thats the fix everyone talks about ......... now as far as your clips "falling down" as you said ..... well as long as they are still inbetween the arm and the shock tower and cliped on the hinge pin then your fine .... it doesnt matter where the lip (used to pull the clip off ) is at as long as the clip remains on the shaft you are fine ........ worst case if you loose one just cut a small piece of fuel tubing the same thickness as the clip and pull out the hinge pin and put the piece of fuel tube on the shaft as you insert the pin into its hole that should take caree of it
