Electronic ignition module placement ?
How critical is the placement of the EI module?...I realize that is should be kept away from radio & switch components, but is this something I can bury in a sealed fuse ~ with little to no access to it? I would like to place it on the inside of the firewall, but access to it would be limited at best. Also....is there any issues with the electronic ignition being close to the gas tank/lines?
Engine: MVVS 35
Airplane: Dynaflite Super decathlon
Thank you for your help.
Tom
