I am putting together my easystar now that all the parts have arrived. Since I did not purchase the RTF version, the motor controller they would have given you isn't povided. If using a different model, the instructions recommend beefing up the motor's interference suppressor to be on the safe side using a capacitor. I am using this motor controller:
http://www2.towerhobbies.com/cgi-bin...?&I=LXHUZ4&P=7
With the standard easystar 400 motor can I connect directly to the engine tags with a wire into this controller? Do you think I need to add on the additional capacitors?
Second question: When using CA to join the plane together, do you need to use kicker? Does it just take longer, or will the bond not be as strong without it?
-Brett Welter
