RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-31-2006 | 11:40 AM
  #2734
novielo
Default RE: Air Hogs Aero Ace!
djstinger, here<s a link that will maybe help you on your way ; http://www.infidigm.net/articles/solder/
if you did not purchase the resistors glued to the fet from meabyte, i would sugest that you use regular resistor (1/4 watt) with 30 ga braided wire (or smaller). you just have to solder one end of the wire square with the resistor, once made it's easier to "point and shoot" on your pcb 'cause you only have to point one end at the time... (is that clear??? i feel like it's much clearer in my mind[sm=bananahead.gif]) it's not an easy task but if you take your time and relax it should be fine
